2002 SAN with electrical problem?!
  • jesl_303
    • Jun 2010
    • 6
    • Boulder, CO
    • 2002 Super Air Nautique
    Last season, my 2002 SAN started giving me some troubles, and I am just wondering, if anyone out there has had this happen to their boat too! Please help! I really want to get out this summer behind my own boat.
    The issue started with the boat periodically dying and the check engine light coming on. It was as if it was overheating, but temp gauge showed middle to high temps (not extremely high). If we shut the boat down and waited a few minutes, it would fire up and run sometimes with no problems and sometimes shut down automatically, with check engine light on a few minutes later.
    After paddling in a few times or needing a tow, and not wanting to damage anything; I took it to two different shops, the second one being a Nautique dealer. The first shop stated the ECM was not responding, so they did not know where to begin looking for a problem to resolve.
    The second shop just stored by boat for a month or so last summer, saying they were waiting for Nautique to send wiring schematics, which never happened.
    With a basic wiring schematic I found here on PN, a mechanic friend and I were at one point able to bypass a relay and again were able to get back out on the lake. Briefly, until the same automatic shutdown started again more frequently. Lastly, the relays were replaced, because of another article I found on PN, and some love was given to the connection points.
    This is where it gets fun. With all new relays the boat would allow the security code to go in but when you the start button was pushed, but instead of turning it over it seemed to short out and die.
    Eventually, the ignition keypad quit lighting up and the boat was unresponsive, so troubleshooting is no longer possible. A couple different batteries were used.
    I have finally located the most pertinent info from PCM and I am considering having someone replace the wiring harness. Maybe I should be looking for a new ECM too?
    Yes, I am seeing the $$$$ rack up, but I am not sure what other options I have.
    Any thoughts?
    Thank you, thank you!
  • Quinner
    • Apr 2004
    • 2245
    • Unknown
    • Correct Crafts
    Unfortunately it does not sound like you have found any decent service/mechanic/marina in your area. Are you trying to repair yourself or find someone who can do it??
    If you are capable of DIY I would inspect/clean/tighten all your major electrical connections including the grounds to start with, unless you find specific problems or the boat came from a salt environment just replacing the harness would not be the best place to start imo.
    ​Also what motor, GT-40, Excalibur, Python, ???
    • jesl_303
      • Jun 2010
      • 6
      • Boulder, CO
      Its an Excalibur engine.
      The local nautique dealer here in Denver wasn't able to help me much last summer, so I was forced to DIY it myself and replaced some relays. I've still been talking a few mechanics and PCM, but cleaning and tightening everything is a good place to start, thanks.
      I've read about the safety harness failing, plan to look into that too, any other suggestions?
      • Quinner
        • Apr 2004
        • 2245
        • Unknown
        • Correct Crafts
        If you are talking about the lanyard, with the ignition on, pull the lanyard and then reinstall, you should hear fuel pumps prime up. Bypassing is simple, a little wire and a couple spade connectors is all you need to join the power in and power out wires.
        ​Clean and make sure all your wiring is tight and making a solid connection starting at the battery, example where you say power just dropped sounds like a battery connection issue.
