2007 210
  • jim lindsay
    • Feb 2016
    • 18
    • bc canada
    • 2011 200 2007 210
    we removed the hard tanks in our 210 and replaced them with 800 # bags the bags wont drain I think because the floats from the hard tanks are disconnected and the system thinks the ballast is empty. Does any one know how to over ride the system so it doesn't think its empty.
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Your ballast is on a timer. There is no sensor. You have to keep cycling til the bags are empty. The system will "time out" even if bags are not completely empty.
    Should be same to fill the bags completely as well.
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      In my 06 my floats went out so I unplugged them and had the same issue. Inserted a jumper wire and problem solved...it read full and emptied and would still fill
      Sent from my VS985 4G using Tapatalk
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • jim lindsay
        • Feb 2016
        • 18
        • bc canada
        • 2011 200 2007 210
        it fill fine but wont drain at all. flick the switch to drain and nothing
        d_nodixon where did you run the jumper wire
        in the plug to the float for the ballast ?
        • swatguy
          • 1631
          • 2008 SANTE 210
          Sorry Jim, didn't realize 07's still used that der system configuration. I thought you meant the bag just wouldn't empty in one cycle. Not empty at all.
          • d_nodixon
            • Sep 2008
            • 475
            • Hammond, LA
            • 2013 SAN 230
            Ok...also I am assuming your gauges read empty and your floats are unpluged....on mi,e they had a two prong plug....the side that unplugs and stays in the boat should be female...so a short jumper with ends stripped and electrical tape to secure and all good. It did take a couple times to get it to stay in place securely.
            2013 SAN 230
            2006 SSN 210 (SOLD)
            • jim lindsay
              • Feb 2016
              • 18
              • bc canada
              • 2011 200 2007 210
              Thanks d_nodixon ran the jumper wire and every thing came back to life
              what a great place to get onfo
              • swatguy
                • 1631
                • 2008 SANTE 210
                Learn something new everyday. Never new of that issue either good info
                • d_nodixon
                  • Sep 2008
                  • 475
                  • Hammond, LA
                  • 2013 SAN 230
                  Glad I could help!....you can almost always find an answer here...great site#
                  2013 SAN 230
                  2006 SSN 210 (SOLD)
