I'm having problems with the smaller round gauges, volts, oil pressure on the right side of the dash console. They are going dead intermittently, freezing in last position and backlight going out. The 2006 210 has a different faria gateway then the 2005, no pitot tubes. I opened the gateway, no corrosion inside and everything looked fine, connections to individual gauges behind console are all secure..... Any ideas? Faria does not sell nor will they repair the gateway
NautiqueParts has the gateway if you decide you need it. It isn't cheap. If you order one, be sure to use our discount code (PND) for 10% off.
http://www.nautiqueparts.com/boxgate...onsgw0019.aspxI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I had an 06 210 and the same issue with a couple small gauges. I would check all grounds first, then make sure there is no corrosion in the connectors for the gauges. The gauges daisy chain from one to another I believe. I would definitely change the gauge before the gateway box. The little ones are about 80 dollars from np. And that was the fix for mine. Not saying this is your issue but figured I would chime in. You are correct they changed the gateway box in 06. While we are on the topic anyone know what year they stopped using gateway boxes? Or are they still being used in Nautiques today?2009 Super Air Nautique 210 TE
1989 Sport Nautique
Anybody have a way to test these guages to see if it's the guage? I totally agree about not replacing the GW0019C if I don't have to since they are hard to find and cost $1500!!! I also dont want to replace the gauge for $80 and then find out its the gateway. Im wondering if the fact that the internal lighting in the gauge is not working also points to it being a gauge failure?
I had issues with mine and ended up being the gauges. Got mine from a fellow PN member who upgraded his to the newer style, which came out looking great.
Sent from my VS985 4G using Tapatalk
2013 SAN 230
2006 SSN 210 (SOLD)
I would pull the dash off and look at the wiring before ordering new gauges. The wiring is daisy-chained on those gauges I believe, and a break or short in one wire can cause issues on multiple gauges, depending on where the wiring issue is.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by NautiqueJeff View PostI would pull the dash off and look at the wiring before ordering new gauges. The wiring is daisy-chained on those gauges I believe, and a break or short in one wire can cause issues on multiple gauges, depending on where the wiring issue is.
Try swapping places with a gauge that works, the daisy chain wiring allows you to put the small gauges in whatever order you want.
If the gauge is working in a spot closer to the gateway then it would be a wiring issue.
______________________________________
2006 SN 196 Limited Excalibur
2001 Super Sport Limited GT402018 Ski Nautique 200 TE, H6
