Faria Gauge Calibration
  • MaineDR
    • May 2015
    • 131
    • Austin, TX
    • 2000 SAN
    So I got the boat out yesterday to test the new gauges. I ran into a problem with the speedo. The new faria speedo was about 10 mph too fast compared to the perfect pass. Perfect pass is fairly accurate from what I can tell. The faria gauge came with a pot adjustment but even with that the correction seemed to fall out of the range of the adjustment to properly calibrate. Anyone had a problem with this before and know how to fix it?
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    http://faria-instruments.com/site_manuals/IS0105H.pdf
    1. Coarse adjustments may be necessary due to variations in
    hull shape and mounting limitations. The coarse adjustment
    is made by turning the six-position selector switch at the rear
    of the case. Start with the switch in position 3 or 4. Increase
    the setting if the speedometer reads high or decrease the
    setting if the speedometer reads low.
    2. Fine adjustments. Remove the weather seal plugs on the
    rear of the speedometer located in the holes marked “ADJ”
    3. With the boat at the known speed, carefully vary the
    appropriate adjustment pot (through the hole in the case) with
    tool provided (5/64” Allen wrench) until your Faria Marine
    Instruments speedometer is in agreement with the boat’s
    known speed. Turning the pot clockwise raises readings,
    counter clockwise lowers readings.
    I think the external pot replaces the internal one, but there is a coarse switch on the back of the gauge. You probably have to change that.
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
    • MaineDR
      • May 2015
      • 131
      • Austin, TX
      • 2000 SAN
      Thanks for the help. That sounds like an easy fix.
