AN 226 Starboard Ballast Pump
  • scottwilk
    • May 2014
    • 25
    • Charlotte, NC
    • 2003 Air Natique 226 Team Edition
    Has anyone had experience changing this? I have an 03 and I followed the fill to the ball valve and then I can barely make out the white pump up underneath the floor and back bench seat. Before I started dismantling everything I was hoping for some coaching.. Any advice or tips would be appreciated.
    I can hear the pump come on when I depress the fill button, but it does not pump in, so my assumption is the pump is bad?? Thanks in advance for any help.
  • Joshf
    • Aug 2012
    • 23
    • Salt Lake City, UT
    • 2008 Super Air 220
    I would check the impeller in the pump if you can hear the pump running but it is not filling. My ballast impellers looked to be in ok shape last year, but were not filling. I replaced them, and no problems since.
