How do I remove a broken paddle wheel
  • lukeaandrew
    • Feb 2016
    • 34
    • Raleigh, NC
    • 2006 Air Nautique 210 TE
    I need to replace my paddle wheel. I can't figure out how to get the old one out.
    Any input would be great!
    Thanks,
    Luke
  • cmcmechan
    • May 2014
    • 24
    • Alberta Canada
    it should un-screw from the thru hull fitting, you may have to cut some safety wire
    • swatguy
      • 1631
      • Midwest/ Northern IL
      • 2008 SANTE 210
      Unscrew the locking cap off the paddlewheel unit. Pull it from the through hull. Use a pointy object and a hammer to tap the paddle wheel pin out of the housing holding the actual wheel. Reinstall. Just make sure when you put the new "wheel "in the unit the paddles/fins are facing the correct way. The flat portion faces the bow.
      • lucky7t
        • Mar 2011
        • 1306
        • Oklahoma
        • 2015 SANTE
        Inside the boat the sensor has a ring that threads on it . I used a screw driver and a small hammer to tap it to get the ring to spin. Then it will spin off and entire sensor pulls out. Make sure to unplug it so you can get it completely out. I did this in the water one day and was interesting to say the least. Thank goodness it came with a cap I screwed on while repairing it
        Current Correct Craft Boat
        Correct Craft Boats Owned
        • lukeaandrew
          • Feb 2016
          • 34
          • Raleigh, NC
          Thanks guys, I was able to replace it. I was definitely going about it the wrong way prior to this post...
