Gt40 starting issue.... click...click... start.... please help...
  • brettmcox
    • Jan 2007
    • 284
    Is yours doing multiple clucking or just one? Per press/start?
    2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
    • brettmcox
      • Jan 2007
      • 284
      What are the symptoms of neutral safety switch
      • BoardSkier
        • Jun 2014
        • 252
        • Lake Anna, Virginia
        • Air Nautique 226
        Electric all on, no starter at all. Kind of like when you try to start in gear.
        2005 Air Nautique 226
        Supra Comp (prior)
        • brettmcox
          • Jan 2007
          • 284
          Would there be a click... I am thinking not...
          • gmtrainer1
            • Jun 2012
            • 8
            • CT
            • 1998 Super Sport
            I have experienced this issue on 2 different occasions on my 98 SS with GT40. 1st time it was starter solenoid (same as rossrips7)and 2nd time about a year later it was ignition switch.
            Sent from my STV100-2 using Tapatalk
            • ScooterMcgavin
              • 1478
              • 2014 SAN 210 TE
              #21
              Gmtrainer that reminds me... I had a key switch go bad and made the starter act weird at times and click like a bad solenoid on my 89 sport I remember changing out the key switch by recommendation from a friend and it never happened again.
              1989 Sport Nautique
              • brettmcox
                • Jan 2007
                • 284
                #22
                Did you have a key or button pad?
                • ScooterMcgavin
                  • 1478
                  • 2014 SAN 210 TE
                  #23
                  Mine had a key, but even the push buttons have connections inside. I wasn't to sure about it at the time. But it's worth a look.
                  1989 Sport Nautique
                  • rossrips7
                    • Feb 2010
                    • 233
                    #24
                    I have a keypad and prior to replacing the solenoid it would click once each time you hit start and finally start after a couple clicks. It's back to new now after the replacement
                    • brettmcox
                      • Jan 2007
                      • 284
                      #25
                      Ok, all..... thanks!!...
                      Here is where I am at....
                      I am going to take Friday off... (kids... out of town this weekend)
                      I have ordered the starter relay... should be here Friday.
                      I will start by getting a new 1/0 ground.
                      Trun on boat...
                      Kind hope.. the start won't work...
                      If it does not jump the starter by running a wire from hot wire at starter... if starts each time hope it is just the relay under the computer.
                      ??? Can I check the wire go I ng to the relay..?? With volt meter? Test light? ... alone? ..
                      If it will not start with the wire from the hot the small wire on starter... I will replace ground.. aND clean the block aND use to electric grease..
                      If that does not work... I will pull the key pad.. and send it in the white lake to test...
                      • pSchwade
                        • May 2012
                        • 127
                        • Reno
                        • 07' 220 SANTE
                        #26
                        it could also be a bad power cable running to the starter/solenoid, the external solenoid should have 4 terminals (2 small for signal, input, and output) you would need to verify voltage at both the input and output terminals while you are trying to start the boat - depending on space it might be a two man job. I think the started is grounded to the block (even on boats) so as long as you have a good ground at your keypad and battery it shouldn't be an issue.
                        • DLafont
                          • May 2009
                          • 340
                          • Gatineau Qc
                          #27
                          Mine does a single click per button push, eventually started every time last summer, but getting new solenoid put in soon. Will try to remember to update you all on result.
                          Previous: 1990 Ski Nautique
                          • rossrips7
                            • Feb 2010
                            • 233
                            #28
                            If the solenoid doesn't fix it id be surprised. It looks like a cheaply made part and from the sounds of it we have all had one fail on us!
                            • DLafont
                              • May 2009
                              • 340
                              • Gatineau Qc
                              #29
                              I guess that it's like in any system, the weakest component leads to failure. $25 part can leave an expensive boat dead in water...
                              • Fast351
                                • Oct 2006
                                • 315
                                • Winsted, MN
                                • 2001 Ski Nautique
                                #30
                                BTW, you do not need to order this part from a marine place. It is the same ole starter relay that Ford has used in countless cars and therefore available from any decent auto parts store:
                                http://www.napaonline.com/napa/en/p/...4SB_0145398101
                                My closest store is NAPA for example. I just mention this because it sure sucks waiting a week for a part when you can just drive 10 minutes to your local auto parts store and fix the boat.
                                2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
