Is yours doing multiple clucking or just one? Per press/start?
2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
What are the symptoms of neutral safety switch2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
Would there be a click... I am thinking not...2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
Gmtrainer that reminds me... I had a key switch go bad and made the starter act weird at times and click like a bad solenoid on my 89 sport I remember changing out the key switch by recommendation from a friend and it never happened again.2009 Super Air Nautique 210 TE
1989 Sport Nautique
Did you have a key or button pad?2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
Ok, all..... thanks!!...
Here is where I am at....
I am going to take Friday off... (kids... out of town this weekend)
I have ordered the starter relay... should be here Friday.
I will start by getting a new 1/0 ground.
Trun on boat...
Kind hope.. the start won't work...
If it does not jump the starter by running a wire from hot wire at starter... if starts each time hope it is just the relay under the computer.
??? Can I check the wire go I ng to the relay..?? With volt meter? Test light? ... alone? ..
If it will not start with the wire from the hot the small wire on starter... I will replace ground.. aND clean the block aND use to electric grease..
If that does not work... I will pull the key pad.. and send it in the white lake to test...2001 Super Sport - GT40 1986 SN2001 - 351 1973 Cobalt - 188/888 2014 F150 Screw 3.5 twin turbo 2011 Expy 2002 F150 SCrew 2001 F150 SCrew 1973 K5 (toy) 1995 Burb 3/4 454 1991 K5 Blazer (DD/Toy) 1987 Honda Accord 1978 Ford F100 1981 Merc Capri 1991 Honda Civic 2002 Ninja 500R sold...
it could also be a bad power cable running to the starter/solenoid, the external solenoid should have 4 terminals (2 small for signal, input, and output) you would need to verify voltage at both the input and output terminals while you are trying to start the boat - depending on space it might be a two man job. I think the started is grounded to the block (even on boats) so as long as you have a good ground at your keypad and battery it shouldn't be an issue.
Mine does a single click per button push, eventually started every time last summer, but getting new solenoid put in soon. Will try to remember to update you all on result.Current : 2000 Pro Air Nautique, Silver&Black accents, pulled by 2012 black Chevy Tahoe
Previous: 1990 Ski Nautique
Originally posted by rossrips7 View PostIf the solenoid doesn't fix it id be surprised. It looks like a cheaply made part and from the sounds of it we have all had one fail on us!
I guess that it's like in any system, the weakest component leads to failure. $25 part can leave an expensive boat dead in water...Current : 2000 Pro Air Nautique, Silver&Black accents, pulled by 2012 black Chevy Tahoe
BTW, you do not need to order this part from a marine place. It is the same ole starter relay that Ford has used in countless cars and therefore available from any decent auto parts store:
http://www.napaonline.com/napa/en/p/...4SB_0145398101
My closest store is NAPA for example. I just mention this because it sure sucks waiting a week for a part when you can just drive 10 minutes to your local auto parts store and fix the boat.
2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
