Fresh water flush system
  • Hockeyrules
    • Oct 2015
    • 15
    • LaPlata MD
    • 2006 sante limited
    I have 2006 220 Super Air. When using the factory fresh water flush system, is it normal for water to flow out from around the prop shaft?
  • WakeHawk
    • Feb 2016
    • 48
    • Washington
    • 2008 SANTE 210
    Yes that is normal.
    • homer12
      • Feb 2016
      • 584
      • Indianapolis, IN
      • 2004 SV211 TE
      Sounds like that would be your dripless shaft seal. Puts raw water around it to cool it
      • vvfdfirefighter
        • Sep 2015
        • 147
        • Carrollton, VA
        • 2007 Super Air Nautique 220 TE
        Absolutely Normal. You have the Dripless shaft seal. Some water after the transmission cooler is routed to that seal and is used to keep the seal and shaft cool.
        2007 SANTE 220 - ZR 6 Engine (Bought 2015)
        1999 Supra Launch (Bought in 2013)
        1987 Supra Marauder - 454 big block (Bought in 2000 - Sold 2015)
        • Hockeyrules
          • Oct 2015
          • 15
          • LaPlata MD
          Thank you for the responses. Greatly Appreciated!
