New mystery electrical problem, 20A dash fuse keeps blowing...
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    I'm getting REAL tired of electrical problems with my 2001 Ski Nautique. So a little back story:
    I bought this boat new to me last fall. Ran it once without issue. Rewire entire dash with new Faria gauges. Go to start it this spring, and it blows a fuse when I try to start it in the driveway. Chase it down to a crappy positive clamp, causing the starter to draw all its current through the ignition lead from the dash. Replace battery clamps, everything is happy.
    Ski several times this year, notice that sometimes you have to push the start button several times to get the starter to catch (see click. click. click. start. thread). So I set out to replace the starter relay after measuring everything and finding it bad. It's kind of a b!tch to get to BTW. Anyway, I replace the starter relay, go to fire up the boat, it cranks first try, but as soon as I let go of the starter, the thing blows the 20A dash fuse again. That's where it sits on the lift today. I checked all the connections, everything is tight. Replace the fuse, try again. Same result. Replace fuse again. Try just turning on the ignition by quickly pressing the start switch. It blows just turning the ignition on!
    Now, I have two schematics for this boat. I have attached both below.
    GT_40_DIAGRAMS.pdf ENGINE%20MANAGEMENT%20HARNESS%20WIRING%20DIAGRAM.pdf
    As near as I can tell, the ONLY thing coming from the dash that powers anything engine related with power going through the 20A fuse is the purple "IGN" wire. It runs to two things. The field wire on the alternator, and the relay that controls power to the EEC. When the boat is cranking, the power to the field wire and the EEC system relay are coming through the starter relay. When not cranking, the power reverts to being fed from the dash.
    This might explain why the old starter relay went bad. What it doesn't explain is why it is now blowing fuses when it didn't when it was bad. I'm going to go check both the field wire and the EEC relay to see if either has a low ohms across it. The only other thing I can think of is that the wiring somehow got compromised when I unplugged the two relays (I had to get the wiring out of the way to get the bolts for the starter relay out).
    Has anyone ever ran across this problem before? How did you fix it?
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
  • pSchwade
    • May 2012
    • 127
    • Reno
    • 07' 220 SANTE
    Im no expert, so hopefully someone else will jump in - but from looking at the two diagrams, does the fuse blow if you remove the fuel pump relay? the relay shouldn't be able to draw 20A, but there might be a short that is causing it. the only other thing it looks like it might be is that one of the diodes might have blown and is shorted (happens in about 1% of the time when a diode fails). If you have a mid range VM it will be able to test it.
    • Fast351
      • Oct 2006
      • 315
      • Winsted, MN
      • 2001 Ski Nautique
      Well, found the problem. New starter relay with dead short between the I terminal and ground. Replaced it, all is well.
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        gotta love new parts bad out of the box!!!
        2005 SV-211
        • pSchwade
          • May 2012
          • 127
          • Reno
          • 07' 220 SANTE
          At least its fixed!
