Gel Coat Repair Question
  • J10
    • Jan 2014
    • 66
    • Toledo, Ohio
    • 1996 Nautique Super Sport
    Do you need to put a piece of plastic (saran wrap) over the gel after filling a spot??? I bought the Spectrum kit, and it doesn't say to do it, but all the videos I see, people are doing it. Any info would be great, thanks
  • xlair
    • 694
    • Wisconsin
    It doesn't hurt. Helps to level out the repair so you have less sanding to do
    2001 Pro Air Nautique
    • HyperliteCowboy
      • Oct 2015
      • 103
      • FL
      • 2016 G23 XR550
      Yes, get clear packing tape. You want to seal out all the air you can from the curing gelcoat. And like xlair said, it helps to level out the repair too, so less sanding is required.
