Starter Solenoid Replacement on 2002 SN 196
  • DannyG
    • Aug 2014
    • 2
    • MI
    • 2001 Super Air Nautique
    I need to replace the starter solenoid on my SN. It is a starter mounted solenoid so currently connected to the starter. On nautiqueparts.com they do not have this individual solenoid and said if that went bad I will need to replace the entire starter. I have a hard time believing this and was hoping someone could point me in the right direction of where I can find just the solenoid for the starter to replace.
  • SurfingCane
    • Jan 2016
    • 144
    • Raleigh, NC
    • `13 G23
    Hey, I have an `04 210 with the PCM 330 Excalibur engine. I had a starter problem also. Intermitting click, click, click.....like a dead battery in a car. Pulled the starter and diagnosed it as just the solenoid being the problem. I took the starter assembly to a local auto/marine electrical shop and they replaced just the solenoid for me and while they had it reconditioned the starter motor also. So far so good and it works just fine. Only cost me $60. Try finding a local shop that specializes in automotive electrical repair/maintenance.....ie. starters, alternators, etc. They should be able to fix you up.
    KEEP
    CALM
    AND
    WAKESURF
    ON
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      http://www.napaonline.com/napa/en/p/...171_0306537918
      if you have the chevy
      2005 SV-211
      • Fast351
        • Oct 2006
        • 315
        • Winsted, MN
        • 2001 Ski Nautique
        2002 is the last year of the GT40 I believe. It was the changeover year anyway. If you have the Ford, here is your correct part:
        http://www.oreillyauto.com/site/c/de...5060/01931.oap
        2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
