Back story. This will be my second season owning this boat ( any boat), and my first time starting it up after winterization. 2003 210 Team Edition
I took the boat out on the water for the first time to check that everything worked well before the holiday. Started up just fine but started to over heat the moment I got above 2000 rpms. Got it back on the trailer and took it home. The dealer I bought the boat from said they replaced the impeller but I figured that would be the first thing to check. So I found Jeff's step by step and got busy. The moment I pull off the incoming water hose I find a large chunk of rubber. Problem solved. HOWEVER where is the dang belt tensioning bolt. I cannot seem to find that bolt or figure a way to do it without damaging anything.
If anyone has a picture or is able to describe which bolt I need to loosen up to get the stupid belt off that would be amazing!
Thanks,
Nate
Thanks,
Nate
