Just purchased a brand new 2015 and have had it in the water 2 days, so far I've had 2 diagnostics DTC 1415 and DTC 1416 related to EMWT2 higher than expected stage1. This comes on when I'm putzing around or sitting idle, no issues when driving at a cruising speed.
Bigger concern, filled the ballasts and powered on the boat and the LINC screen went dark and then showed a thumb drive (a software update issue???) and noted
Ver 2 3 20045 RELEASE
Part#:
Ser #: 11
16
10
I turned the batteries off and on several times, no change, finally after leaving powered off for half an hour, it went to home screen, was able to empty the ballasts (so I would be able to put it up in the hoist) but then the screen was stuck on the lighting switches screen. It would not switch to any other screen.
Any thoughts on any of the above are much appreciated!!
Part#:
Ser #: 11
16
10
