Prop Recommendations?
  • TexTique
    • Apr 2006
    • 3
    • Georgetown, TX
    Hey guys,
    New user here, wondering if I could get some recommendations on prop selection. I've got a '91 Ski Nautique that I bought used a couple of years ago and have slowly been getting it back into shape. The current prop is a 3 blade 14" RH 16 1" shaft. The engine is the stock PCM with a 1:1.23 tranny.
    We've gotten into wakeboarding recently and I'm wondering if a new prop might be called for. I've already got the tower and will be adding ballast soon. I'm exploring the idea of changing to a 4 blade if that will help or if I should just stick with what I've got.
    Any ideas would be appreciated. Thanx!
    -Craig
  • Luke
    • Mar 2003
    • 509
    • Des Moines, Iowa
    RE: Prop Recommendations?
    I would recommend calling ACME: 1-888-661-ACME
    They will ask you questions about how you want your boat to perform and will let you know what props would work best and what they will do for you.
    • TexTique
      • Apr 2006
      • 3
      • Georgetown, TX
      Luke,
      Thanks for the advice. I'm planning on doing that tomorrow. I'm also hoping to hear from others who might have first-hand knowlege on here as well.
