Breaker Switch Amperages
  • TWags
    • Jun 2004
    • 5
    • Central Ohio
    I have a '97 Ski w/GT40 engine. In doing a little clean-up, I'd like to replace a few of my breaker switches, as a couple of them are getting a little touchy after more than a few years of use. I'd like to replace the following breakers, but would like to confirm the amperage on the '97:
    - ignition (I'm guessing 20A?)
    - blower
    - Accy 1 (seems like maybe 10A if all Accy breakers are the same)
    I've looked through the manual (and some of the newer manuals), and there isn't much information about the breakers in there.
    If anyone has pulled a few of these and has a run-down on the amperages, that would be great. Thanks!
  • M3Fan
    • 1034
    RE: Breaker Switch Amperages
    The old breakers should have the amperages written on the back of them. I believe the blower is 6A.
    2000 Ski Nautique GT-40
    2016 SN 200 H5
    www.Fifteenoff.com
    • TWags
      • Jun 2004
      • 5
      • Central Ohio
      M3Fan, I'm guessing you're right. I was hoping to take the easy way out: order the switches without digging them out of the dash more than once. Ultimately, it doesn't seem to be too difficult getting them out of there, but if anyone has them documented, I would certainly take that route. Thanks.
      • TWags
        • Jun 2004
        • 5
        • Central Ohio
        Thought I'd answer to some of my own questions here. If I would have looked a little closer I would have seen this earlier. As it turns out PlanetNautique's friends over at White Lake Marine have the answer.
        If you go to their online store and check out the electrical/dash section, there is a description of each of the switches and their typical usage (ignition, blower, accessories, etc.).
