Tags: None
Originally posted by Nautiquehunter View PostI had the same thing on my 84 . You need a primary float bowl . They are available at Summit about 50.00 plus shipping . May as well order the gaskets and o rings at the same time.
I believe this is the correct primary float bowl... http://www.summitracing.com/parts/hly-34r10918aq
I'm completely lost on which gaskets & o rings I will need, though. Any help?
Is it as simple as...
1. Shut off the gas.
2. Remove the old bowl.
3. Transfer all the parts (float, needle, seat, etc. )over to the new bowl.
4. Reinstall the new bowl with a new gasket?
I've never done any carb work before...
Just be sure you are very clean with everything. Don't let any dirt get in anywhere. It's been awhile but I have rebuilt a carb before and know that even a spec of dirt can block a passage in a carb. You shouldn't have to 'shut off' the gas technically, just un hook a battery cable if anything. That bowl will have fuel in it though that will pour out when you remove it. I try to catch as much as I can... After I am done, and everything is sealed back up, I flood the area with water and flush through the bilge/drain plug to remove any trace of fuel and let air out good... Use a little dawn soap as that breaks down grease/oil/gas better. imo
[QUOTE=shag;n488148]Just be sure you are very clean with everything. Don't let any dirt get in anywhere. It's been awhile but I have rebuilt a carb before and know that even a spec of dirt can block a passage in a carb. You shouldn't have to 'shut off' the gas technically, just un hook a battery cable if anything. That bowl will have fuel in it though that will pour out when you remove it. I try to catch as much as I can... After I am done, and everything is sealed back up, I flood the area with water and flush through the bilge/drain plug to remove any trace of fuel and let air out good... Use a little dawn soap as that breaks down grease/oil/gas better. imo[/QUOTE
Thanks.
I'm getting my list together. In addition to the float bowl I linked above, I believe I need the following...
(4) Primary Bowl Screws http://www.skidim.com/SCREW-CARB-BOW...tinfo/R009142/
(1) Primary Bowl Gasket http://www.skidim.com/GASKET-PRIMARY.../HLY-108-83-2/
(2) Fuel Transfer Tube O-Rings I'm not sure about these. I see a couple of options... http://www.summitracing.com/search/p...Tube%20O-Rings Do I want the Viton or rubber ones?
Anything else I need?
