DTC 502 Roadspeed input loss of signal LincII 2013 230
  • lance2skyhigh
    • Jun 2008
    • 12
    • Arnold, MD
    • 2013 230 SANTE
    Just picked boat up from Dealer and had this code first run out on acceleration. Everything is working except the speedometer, which keeps the NSS from working also. Is anyone failure with the speed control system? I have a GPS location. The gps is showing a circulating blue ring which I do not remember seeing in the past?
    Current Correct Craft Boat
    2013 SANTE 230
    Correct Craft Boats Owned
    2007 SV211
    1996 196
    1984 2001
  • nohlan_4
    • Jan 2016
    • 413
    • Canada
    • 2013 G23 450
    Just went through the same thing on my G23. On the gps utilities page in the Linc screen do you show any gps satellites active? Mine ended up being a failed GPS antenna/puck. Replaced it and it was good to go.
    • lance2skyhigh
      • Jun 2008
      • 12
      • Arnold, MD
      • 2013 230 SANTE
      It does show gps satellites. Is the speed control only based on gps, or does it use water pressure also?
      2013 SANTE 230
      2007 SV211
      1996 196
      1984 2001
      • nohlan_4
        • Jan 2016
        • 413
        • Canada
        • 2013 G23 450
        So you actually show a latitude and longitude? On gps equipped boats yes the gps is the only signal. Could be a problem with the linc, have you tried running an update on it?
        • toddo75
          • Mar 2009
          • 35
          • Clermont, FL
          • 2015 G21
          I just got a new Nautique 210 and the same thing haoo Ned to me. How did you all resolve this issue? Thanks
          2004 Super Air Nautique
