I only know the abosolute basics when it comes to motors so please be gentle.
Before I took the boat out this year I noticed my existing belt on the alternator was hanging by a thread. It said 3L390 on the belt and was GREEN, so I found a similar belt at a hardware store but it was BLACK. I couldn't get the bleeping thing on! it was too small even after removing both bolts. So I bought 3L400 which seemed to be the right size. Well anyway I had to call it quits within 2 hours the last 2 times out as the belts starts smoking and basically getting destroyed. While on the lake, I would tighten the tension because I thought maybe these belts couldn't handle the high heat.
Are my belts not strong enough or heat resistant enough?? what belt type, brand and size should I be using??
Is my alternator going bad? It did seem pretty hot, so to retighten the belt I had to use a folded up damp towel on the alternator. the voltage gauge would be around 13 then dip to 12 when the belts were failing. If I need a new alternator what should I get? There is 3 pulleys total, what is connected to the other pulley? could that be my problem?
Very frustrated! and would rather not bring it in and loose another weekend, but maybe that's my best bet.
