So I thought the only transmission I needed to check was the v-drive unit. Why can't I find where to check the regular transmission oil. Could someone attach a photo or diagram? I could not find one anywhere after searching online and the manuals.
I don't have a picture but assuming it is the same as my 99 Super Sport I can try to explain it. It's on the starboard (driver's side). You will likely need to remove the backseat rest and the divider boards behind it in order to see it. Mine has a small circle ring that you can twist and pull out to check. I just googled and found a pic of a similar tranny out of the boat that might give you a better idea of what you are looking for.
http://www.pleasurecraft.com/NewFiles/trans-little.jpg
Shawn
2012 Blue Metal Flake SAN 230
