Replace docking halogen lights to LED?
  • hawaiianstiln
    • Jul 2015
    • 47
    • Lambertville, MI
    • 2006 SAN TE 210
    Has anyone ever replaced the MR16 Halogen 50 Watt Docking light bulbs to LED? If so, do you know which LED bulbs were used? I tried to find 50 watt equivalent in LED for the MR16 type bulb and it seemed like nothing correlated to 50 Watts. If I go LED I would assume I want the Spotlight type LED version for docking lights?
  • shag
    • 2217
    I did. I can't remember what watt they were but got them at Lowes.. I like the result..
    • hawaiianstiln
      • Jul 2015
      • 47
      • Lambertville, MI
      • 2006 SAN TE 210
      okay so if you got them at Lowes I've seen the MR16 LED version. However, I noticed on the package it said something like 12 watts equivalent and was thinking it would be nice to get the 50 watt equivalent, but maybe that is overkill when it comes to LED version
      • homer12
        • Feb 2016
        • 584
        • Indianapolis, IN
        • 2004 SV211 TE
        I don't know why you wouldn't want the option with the most output... I say brighter is better for what your using them for - docking the boat or navigating.
        • shag
          • 2217
          I'm sorry I can't remember the actual wattage, but I am pretty sure I put the 50W equivalent in, which just had more LED's in the light than the lower ones. I believe 5-5 LED's in the light. I feel it is brighter and it barely moves the volt meter if at all, whereas the halogens were a pretty good draw.
          • bdisney3
            • Feb 2016
            • 205
            • Phoenix
            • 2021 G23 (on order) 2018 G23 (for sale)
            I have replaced the Halogen 50W ones with LED ones - I used these: https://www.amazon.com/Halogen-Equiv.../dp/B00XBZ16PO - brighter than original, not hot at all, and shouldn't have to replace again down the road! Uses 6.5 Watts and says to be equivalent of 50W Halogen - like I said, seems brighter than orig to me though.
            bdisney3
            18 G23
            09 SAN 210 TE (previous)
            04 Supreme V220 sp (previous)
            94 Four Winns Horizon (previous)
            • hawaiianstiln
              • Jul 2015
              • 47
              • Lambertville, MI
              • 2006 SAN TE 210
              Thanks bdisney3. I will check that out. I did a test on my volts and when you turn on the mfg 50w halogens it drops the volts 1.2 volts (went from 12.7 to 11.5 instantly). So getting rid of the halogens is the way to go for sure! Looks like you are in PHX. I was there from 05-2012 after I move from Hawaii to phx. Loved it there, grew into the wake community big time. Lots of friends out there for sure and the AWA. I was always the outlaw tho since I sponsored/support Ronix and they are big hyperlite/LF community. lol..
              • hawaiianstiln
                • Jul 2015
                • 47
                • Lambertville, MI
                • 2006 SAN TE 210
                went ahead and got the 60 watt version, hoping to see a huge difference: http://www.amazon.com/Equivalent-Spo...11&s=hi&sr=1-1
                • theskunk
                  • Oct 2014
                  • 232
                  • Stafford, VA
                  • 2006 sv-211
                  Did you end up getting these? This is on my winter upgrade list.
                  Thanks!
                  • hawaiianstiln
                    • Jul 2015
                    • 47
                    • Lambertville, MI
                    • 2006 SAN TE 210
                    Yes I did end up getting them and they are much brighter!! took me about 20 min to switch them out. When I would turn my old ones on the voltage drop was like 1.3 volts. When I turn the new ones on the voltage drops 0.1. (if I recall)
                    • homer12
                      • Feb 2016
                      • 584
                      • Indianapolis, IN
                      • 2004 SV211 TE
                      Do you change these bulbs from the backside or pulling the lenses off the front outside of the bow?
                      • hawaiianstiln
                        • Jul 2015
                        • 47
                        • Lambertville, MI
                        • 2006 SAN TE 210
                        you have to take the lens off. BUT, be careful with the springs that hold the bulb down once you take off the lens. You can stretch these and or ruin them. So I basically took one of the springs off carefully and then pulled the bulb, then replaced with new LED, then re-attached the spring. Then screwed the lens back on, Voila.
