Perfect pass 220
  • wviveen
    • Dec 2004
    • 133
    • Santa Monica
    • 2016 Nautique G23
    Perfect pass 220
    Does anybody know the correct settings of Perfect pass for a new 220 air nautique ? We have tried several settings for KDW and NN but could not find the correct settings.
    Fluctuations in speed were around 4 to 6 KPH with almost all settings we have tried.
    Anybody ?
    ps. only stock ballast.
  • skinautique
    • 1749
    • Colorado
    RE: Perfect pass 220
    you are off that much between PP and the speedo or it is going up and down that much? Lower your KDW setting if that is the case. What are they set to now?
    • wake-sk8
      • Oct 2005
      • 121
      My buddy this weekend had the same problem on his 06 210 SANTE. (Or should I say Air 210 !!). The PP speed seems to fluctuate more than usual, i.e. 4 - 6 KPH and we have no idea how to solve it. Also the bleeper does not 'bleep' when it reaches speed, but PP still works. Again he had stock ballast only, but it just seemed to struggle holding a consistent speed.
      Any replies during this thread would be useful to us too..
      Thanks in advance...
      • wviveen
        • Dec 2004
        • 133
        • Santa Monica
        • 2016 Nautique G23
        The Perfect pass is going up and down with around 4 to 6 kph..
        The initial settings were 120 for KDW and 80 for NN. We have changed them to all kinds of different settings from all the way up to all the way down.
        But it kept doing the same thing...
        • NAWTEAK
          • Aug 2005
          • 192
          • Orlando
          try restoring the factory settings. also i think there are more settings (CR?) that you can play with.
          • Laptom
            • Oct 2003
            • 876
            • Eindhoven, Netherlands
            There seems more problems with the 2006 PerfectPass. Perhaps contacting the dealer about this.
            Also, check if the throttle wire from the servo runs freely.
            • BugHunter
              • Apr 2006
              • 4
              I have a 2006 X-Star which uses the same electronic throttle system and I had the same problem.
              I also had weird stuff that clearly was caused by software 'bugs'. Like a quick up-down-up-down throttling and going a fixed 3mph slower than the set speed.
              Perfect Pass send me a new chip that fixed this weird stuff.
              The speed problem was fixed by new settings. I will get he settings of my boat later and post them.
              • 2fat2ski
                • Jan 2006
                • 25
                • VanDevere Marine Akron, Ohio
                the latest settings for 2006 models are as follows:
                KDW 60-90
                NN 10-20
                CS 730-755
                These settings are to be used when the boat is being run at capacity level. Hope this helps.
                • wake-sk8
                  • Oct 2005
                  • 121
                  Thanks guys, my buddy and I will give it a try at the weekend. Thanks again..
                  • ScrewPusher
                    • Feb 2006
                    • 77
                    • Isle of Wight County, Va
                    I "PERFECTED" mine a little bit last year, with the help of my 3 year old son, so it's all screwed up. Dealer told me told that there are instructions to return to the original factory settings, he implied they are in the manual, hold 2 bottoms till it resets?????. I have not looked yet. He said that after you re-set, it will ask you about the engine, and if you have the 6.0 answer yes, otherwise answer no. He said if you set up with the wrong engine the PP will hunt 4-6 MPH.
                    • wake-sk8
                      • Oct 2005
                      • 121
                      2fat2ski, thank you. Sorry for the delay in responding but not been out with the boat for a while. I punched in the settings you gave me and they made a great difference and worked first time - spot on !
                      Fluctuation is now less +/- 1kph
                      Thanks again, its appreciated...
