Diagnosing blower issues, 2006 SV211, keypad
  • theskunk
    • Oct 2014
    • 232
    • Stafford, VA
    • 2006 sv-211
    short problem:
    my Blower doesn't turn on. I hear a faint "click" when pressing the button, and a slightly different faint "click" when pressing it a second time. The light also does not illuminate.
    I found a thread that details how to replace the blower, however I'd like to rule out electrical issues, so I'm looking for some information "where to start"... I've checked the breaker, but I'm having trouble tracing the wiring since it's all in the harness heading forward.
    Any suggestions?
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    The blower is located in the engine compartment, pretty sure mine is on the starboard side just inside that panel divider. If you have a multimeter, you can just pop the connector at the blower itself and see if you are getting 12V to the blower from the "boat". If you are, then it is just a bad blower, if not.... then real troubleshooting begins.
    The wiring digram is http://www.planetnautique.com/Correc...ms/2006211.PDF The blower is on the left hand side of the page, near the middle (top to bottom) shown with the neon green connector. That is what i would disconnect and see if it is the blower motor or the boat.
    Tim
    • d_nodixon
      • Sep 2008
      • 475
      • Hammond, LA
      • 2013 SAN 230
      My blower did the same on my 06...and I think it would alway flip the little breaker under the dash...replaced the blower and all good.
      Sent from my VS985 4G using Tapatalk
      2013 SAN 230
      2006 SSN 210 (SOLD)
      • shag
        • 2217
        If that's the original blower I can almost guarantee that it's bad.... EBay is great for finding a quality 3" or 4" blower for a decent price...
        • theskunk
          • Oct 2014
          • 232
          • Stafford, VA
          • 2006 sv-211
          I believe it to be the original blower. My game plan (currently) is to pop the box open and do a quick electrical test at the fuse (sounds like the easiest solution), if that's a no-go, then I'll start looking at pulling out the hard tank. Might also consider doing the tank-buster ballast setup at the same time...
          • azeus17
            • Feb 2008
            • 387
            • Grand Rapids, MI
            • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
            That sounds way harder than just putting a meter on the plug to the blower...just my opinion.
            • theskunk
              • Oct 2014
              • 232
              • Stafford, VA
              • 2006 sv-211
              If I could reach the blower motor with ease, i'd agree with you
