No power to fuel pump
  • hancobar
    • Mar 2016
    • 12
    • cleveland, Tn
    • 2000 SAN with Python engine
    I bought a 2000 SAN with 135 (actual hours) for 12k. Went out on the water and had issues the first time out (other than water testing). Now I'm not getting power to the fuel pump. I have had the fuel pump checked and it's not bad, I have also replaced the 2 relays and in line fuses at the battery. Any help would be greatly appreciated.
  • Tryathlete
    • Feb 2015
    • 217
    • Lake Villa, IL
    • 1996 Nautique Super Sport
    How did you check the fuel pump? Did you check the low pressure and high pressure pumps? Probably best you check over at Correct Craft Fan.....lots of hel from them on this.
    • hancobar
      • Mar 2016
      • 12
      • cleveland, Tn
      I took it off and took it to a boat dealer here in town to try to match it up and they tested it. No I didn't Check those. Ok thanks you for your help.
      • CDP2966
        • Jun 2012
        • 1
        • Discovery Bay
        • 1998 Ski Nautique
        Did you check your kill switch? I had the same issue on a 98 196 and the kill swtch was intermittently failing. I replaced the switch and its been fine. You should hear the fuel pump kick on when you turn you ignition to the on position before starting. I would start here.
        • DLafont
          • May 2009
          • 340
          • Gatineau Qc
          I had to modify the connector (bypass it really) two summers ago when both pumps were misbehaving, turned out that the connector was bad and only supplying power intermittently to the pump.So far the LP pump work like a charm and I added a new HP pump since I replaced the FCC just before this season.
          Previous: 1990 Ski Nautique
