Perfect Pass Question
  • mcbridek
    • 241
    • Raleigh, NC, Lake Gaston NC
    • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
    My boat has the RPM controlled system (PerfectPass S Cruise). If I drive to the desired speed, set the system - works fine. If pull back the throttle (to get the skier in the water) and pull the skier up and engage - not problem the system remembers the RPM setting/speed. But if I turn the key/engine off (skier resting between passes) - shouldn't the system remember the last RPM setting/speed ? Mine does not, you lose the setting unless I am doing something wrong.
    06 Ski Nautique 196 SE (2010)
  • steve578
    • Oct 2005
    • 15
    • Houston
    I have PP Cruise on my 99 Sport. We just started using it. I believe that it is just like a car's cruise control, once you turn off the ignition, it looses the last setting.
    • mcbridek
      • 241
      Ah - same boat -I have a 99 Sport, just added a New Dimension tower (not to get off the subject)
      • steve578
        • Oct 2005
        • 15
        • Houston
        If our boat didn't have the 2000 or newer style tower, I would have done the New Dimensions also.
