PME breaker box keeps tripping
  • Opfire
    • Jun 2012
    • 37
    • Orinda
    • 2005, 226 TE
    the PME fuse box keeps tripping the starter/run fuse when i power up the keypad? This is in a 2005 226TE
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    Check the battery cables to make sure they're not corroded internally. Had this happen on my 2001, and it kept popping the 20A fuse because it was trying to draw all current through that wire instead of the cable.
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
    • shag
      • 2217
      Sometimes it's just a good idea to replace with new cables and ends... You would be surprised the current drain with old cables... Even some that look ok...
