Working on rewiring ballast to control each pump independently. I have created a face plate to replace the tank gauges with switches. I have run wiring to each pump and tied them to switches with individual breakers. Last step is a power source. Any suggestions on where to pull power from that is switched? Original thought is to use the power that is going to the pumps in the original wiring. Not sure where to pick it up. Other thoughts?
Tags: None
So here is the panel I made to replace the tank gauges. Ended up taking power off the battery. Need to find a good switched power.
Sent from my SM-G900V using Tapatalk
