remove/install chromax letter
  • Free48
    • Jun 2014
    • 119
    • Montana
    • 2019 SANTE 230 2017 SANTE 210 2011 SANTE 210 1991 454 BFN 1989 SN 2001 Ski Ray inboa
    Anyone have tips for proper removal and replacement of a chromax letter?
  • mlange
    • 98
    • Oconomowoc, WI
    • 2012 SN 200 Mapple Icon Edition
    Save yourself tons of time and buy a 3M Stripe Off Wheel. Harmless to gel coat and well worth every penny it costs.
    • Free48
      • Jun 2014
      • 119
      • Montana
      Thank you mlange! Just watched a youtube vid on that, definitely should do the trick.
      • xlair
        • 694
        • Wisconsin
        Heat gun would most likely work better and be less messy
        2001 Pro Air Nautique
        • Free48
          • Jun 2014
          • 119
          • Montana
          I was concerned about using a heat gun as there are decals and letters too near the work area. Albeit expensive ($40) the 3M Stripe Off Wheel worked exceptionally well on the adhesive. Imho it was worth the money as there is no collateral damage and the removal took just a couple minutes. The next issue I have is that a JB-Weld type product was also used. Any recommendations for removing dried "JB whatever" without damaging the hull?
          • Free48
            • Jun 2014
            • 119
            • Montana
            The following is from JB Weld's website....
            When fully cured, J-B Weld can only be removed by grinding or filing it off, or by directly heating the product above the 600º maximum temperature threshold.
            So the moral of the story is: Don't use JB Weld on your hull.
            • Free48
              • Jun 2014
              • 119
              • Montana
              So to bring this full circle... after doing some research I determined that my only real course of action was to sand off the epoxy. Once I had it removed I began progressively moving from course to fine wet sand paper and then finished with polish. It looks perfect however it took me almost 3 hours to do a 5"x7" spot. Epoxy is not appropriate for this purpose.
