hey guys, I have to leave and not sure when I will be back. So I figured I would drain my engine and v drive. I have a 2008 Nautique 210 with the 343. I drained the two knocks sensors, two brass manifold, v drive, trans cooler, j pipe, and pulled the red heater hose and blew the water thru j pipe and then poured anti freeze and watched it come out of j pipe location. Is that all? Let me know so I can sleep easy. I hope to be back August just being smart.
Pull both heater hoses insert a funnel in one and pour antifreeze in until it comes out the other reinstall both.There is also a plug on the bottom of the muffler if you have a cat engine. Reinstall all plugs remove the impeller out of the raw water pump . Remove the water hose at the back side of the trans cooler and both sides of the V drive . Remove the hose at the top of the raw water pump turn it up insert a funnel and pour antifreeze into the thermostat housing until it comes out the exhaust . Remove the suction side hose on each ballast pump insert a hose in a gal of RV antifreeze and use the ballast pump to suck the antifreeze out of the gal jug and into each ballast tank.Then remove all the ballast impellers. Put dryer sheets in all compartments to prevent varmints [ it also makes it smell great].
