Tightening Prop Bolts
  • CCC79
    • 26
    I have a super air and the prop support arm needs tightening. Trouble is the 4 screws have bolts on the other end and these are right under the engine. How do I get in to tighten them? At the moment it looks like I have to strip the ballst tanks out etc and even then it might be too difficult. Surely there must be some kind of way round this?
    Help!!!!!
  • richard
    • Feb 2005
    • 406
    • HK
    RE: Tightening Prop Bolts
    Remove the ballast tank you can reach, if the screw are loose ,should take out and put back with marine sealent achive for preventing water leak.
    • CCC79
      • 26
      is the removal of the tank easy enough ?
      • ag4ever
        • 1180
        Remaval is really easy.
        Just two bolts hold the tanks in, and three hoses to disconnect, and they lift out.
        I remove mine for general service when I don't have the dealer do it. It really makes it a lot easier.
        • TrailInn2
          • Feb 2005
          • 40
          • Wisconsin
          I had to tighten these on my 96 Super Sport. I don`t have ballast tanks so follow the other guys advice on removing those. Once they are out the bolts are not hard to get to. I removed one at a time sealed the hole and replaced the bolt and nut. Then for peace of mind put a bead around the bracket underneath. Stopped the leaking!!
          • CCC79
            • 26
            OK, thanks a lot
