2002 Sante Fuel Cell Drain screw
  • wakehead
    • Dec 2009
    • 240
    Hi Everyone,
    It seems that I have water in my gas and other crud that has built up in my tank. I do know that there is a screw on the bottom of the FCC fuel cell canister, but unfortunately the head is stripped. It is a little brass screw and in the manual it says that it is 7/16. I am not sure what that means, but if I can find a way to get this screw off, can I just get another on at the local hardware store, is there anywhere that I can order that online.
    Any help or information regarding this would be very appreciated.
    210 SANTE
  • Jono
    • May 2010
    • 85
    • 1996 SuperSport
    its an allen key. you have to hold the big nut with an open end. i would take the canister off and change the filter if theres that much crud in there.
    • Blamey
      • Sep 2015
      • 595
      • New York
      http://www.skidim.com/KIT-FCC-DRAIN/...info/RK024178/
      • wakehead
        • Dec 2009
        • 240
        This is great.
        Thanks guys
        210 SANTE
