Port Ballast filling, not draining
  • philoni
    • Jun 2016
    • 3
    • St Charles MO
    • 2005 Super Air Nautique Team Edition
    2005 SAN TE - all ballast tanks fill. Port tank will not empty. I can hear a 'click' then I press the button - however empty does not run. I can switch the port pump wiring over to the belly - and it drains. What else should I check?
    Wrestles riders at home!
    Thanks in advance.
  • slidin_out
    • May 2010
    • 169
    • 2003 Super Air Nautique Team Edition
    Sounds like a bad toggle switch if the same set of wires works on a different switch. Should be a quick and easy fix.
    • philoni
      • Jun 2016
      • 3
      • St Charles MO
      Where do I locate toggle switch?
      • pokesgrad02
        • Aug 2012
        • 170
        • Lenexa
        • 2018 SAN 230
        That's what your flipping from drain to fill. Can get them on nautiqueparts.com
        • nr2041
          • Mar 2013
          • 44
          • TN
          • none
          if a te boat then would be either a bad connector or bad keypad, if bad keypad, I'm sorry they are not cheap
          • nr2041
            • Mar 2013
            • 44
            • TN
            • none
            I just replaced a port drain pump, mine was bad original pump, but if your switching wiring and it works I would say it is your keypad
            • philoni
              • Jun 2016
              • 3
              • St Charles MO
              Thanks..back at it this afternoon
