2007 Air Nautique idle speed only.
  • cledonne
    • Jun 2016
    • 5
    • Pittsburgh PA
    • 2006 Air Nautique
    I have a 2007 210 Air Nautique and when I first start going with the boat it gives me idle speed only. After a while I get full power back and the boat runs great, any ideas on what might be the issue?
  • Quinner
    • 2246
    • Correct Crafts
    What motor? Does it have perfect pass? Is it an 06' per your signature or 07' per your post?
    • cledonne
      • Jun 2016
      • 5
      • Pittsburgh PA
      • 2006 Air Nautique
      It is an '06, sorry typo on the 2007, it does have perfect pass (but I don't have it on when it happens) and the engine is a PCM 5.7 330HP. Any help would be appreciated.
      • 210Surfer
        • Jul 2013
        • 23
        • Frisco, TX
        • 2020 210 SAN 2003 210 SANTE
        Sounds like it's going in to limp mode. Check your v-drive fluid level.
        • Quinner
          • 2246
          • Correct Crafts
          Assuming you are not getting any alarms or warning lights it sounds like your PP may be spooling out however if an 06' it should be TBW?? Have any pics of the motor you can post??
          • cledonne
            • Jun 2016
            • 5
            • Pittsburgh PA
            • 2006 Air Nautique
            I don't have any pictures of the motor, but will get some when I go down this weekend.
