Had amp replaced and stereo "tuned" locally on '15 G23, tested at retailer ... worked and sounded great. Went to take boat out on the water two weeks later on the 4th of July and audio controls inoperable on Linc 2.0. Only way to control input and volume is on Polk head unit. In addition no sound out of tower speakers and no zone control. Needless to say not a very happy camper! Called dealer (MarineMax Rodgers, MN) where purchased and they told me it sounds like the Linc 2.0 needs flashed. Has anyone had this problem and had it flashed? Could it be anything else? Closest dealer is NOT close!! Thanks!!
I have seen this issue on a '16 G23, and the flash did fix the issue in that boat.
Maybe they would be willing to send you a USB stick with the update on it. The procedure is easy.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
