Noticed that it drops below 10 when i turn on my ballast pumps. drops below 10 if I turn heater on high at cruising speeds. stereos not that power hungry. the orange indicator lights get real dim also. batt or alternator?
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
RE: low voltage
Before people ask, he has an '02 SANTE.
I would check the main wires from the battery to the power switch and the power switch to the circuit box. On some boats, the wire size is too small, and cannot carry enough current to supply high-power devices. See this thread for more information.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
RE: low voltage
Bad ground...? Check (-) cable to block, clean terminals and clamps on battery and crank them down tight. Eliminate the easy stuff first.
