2004 SANTE integrated bow sac
  • SurfingCane
    • Jan 2016
    • 144
    • Raleigh, NC
    • `13 G23
    It fits under the front/side cushions....like an upside down V . Don't know any better way of describing it. I put my anchor on the port side under the front/side cushion. I can get it out even with the bow sac full.
    I was told by WakeMakers that you can't hook it up to the overflow from the belly tank because the aerator pumps won't fill it completely and the drain pump definitely won't drain it. It has to be plumbed by itself. Plus after getting some thoughts on here I decided I wanted to control all my tanks/sacs separately.
    KEEP
    CALM
    AND
    WAKESURF
    ON
    • Kmayotte
      • Apr 2010
      • 819
      • Lake Winnipesaukee, NH
      I did the same thing in my 04. Cut out the cooler and placed this Fly High Bow Sac underneath. Added a reversible jabsco impeller pump T'd off of the inlet for the belly pump. The sac vents and emptys out the same line as the belly. I installed the switch next to the drivers seat. Cutting out the cooler sucked due to the foam but it was way worth it in the end.
      The guys at wakemakers can help you with every part you need if you email them.
      • prowake
        Banned
        • Jun 2016
        • 43
        • West Palm Beach FL
        • 2003 SANTE
        no, i mean how WELL does it fit.
        I just cut out my cooler today and OMG what a B!TCH
        I used a dremel and by the end it was whining like crazy. Pretty sure I broke it.
        The most challenging part was working around that PVC pipe. Cutting the cooler in 4 pieces helped, but in the end I was able to chisel off the remaining fiberglass surrounding it, so it looks nice and clean.
        all the **** that got removed:
        JUST ordered a fly high integrated sac from wake makers, hoping it will fill all possible spaces.... Im wanting as much weight as possible to balance out my 750s in the rear
        Tried riding the other day and the wake was just too vert. I couldn't hit it hard without being thrown way off axis.
