Gateway Box
  • mmac4756
    • Jul 2019
    • 5
    • OR
    • 2006 Super Air Nautique 220 TE
    Originally posted by NKeith View Post
    Does anyone know where the gateway box is located on a 2006 SANTE 220?
    I have same question...couldn't locate while winterizing. Anyone have a pic of its location?
    • ScooterMcgavin
      • 1478
      • 2014 SAN 210 TE
      Not 100% sure on 220.... But on my 06 210 it was up under the kick panel by drivers feet, check there and good luck.
      1989 Sport Nautique
      • 03SANTE
        • Sep 2018
        • 166
        • PA
        • 2003 SANTE
        The electronic contact cleaner...do you just go to town in there and spray everything? Any blotting it up or does it just evaporate? I was getting erratic behavior with the gauges and planned on doing this in the off season.
        • scottcb
          • Oct 2019
          • 4
          • AZ
          • 2007 Air Nautique 236 Team Edition
          Attention anyone following this thread that may have dealt with these issues successfully - help please. I have been dealing with intermittent working gauges and alarms bells on and off for a year and have slowly tried to chase the issue down. It has to be an electrical issue, but I'm not as familiar with boats as cars. Below I have documented my issues and hoping someone can steer me in the right direction. I don't mind sending it to someone who can fix it (Phoenix, AZ Area), but I don't want to spend money for someone to waste a bunch of time just to tell me they are clueless. Any help is much appreciated!
          2007 236 Team Edition
          My Gateway Box is Part no: GW0020A (not the version with the water pressure inlets)
          Started noticing the following in 2019:
          • Oil Pressure gauge and speedometer (which includes a digital display for the depth finder) would stop working, restart, and then stop again. Depending on the day, it either worked or did not.
          • All other gauges seemed to keep working.
          In 2020:
          • Took it to Century Marine. They stated that the Oil Pressure Gauge and Speedometer were not working and needed to be replaced.
          • Found a New Speedometer online, purchased and installed it. Speedometer did not work, however occasionally the needle bounces up and down just above 5MPH. Oil pressure gauge has been working more than not, but still stops sometimes. I use the digital display on the Tachometer which displays oil pressure, volts, engine temp.
          • All other gauges have been working (Temp, Volt, Fuel)
          • NEW Issue - A high pitch beeping noise will start, sounds like a warning buzzer. It will go off if you turn off the motor and restart the motor, but eventually the noise comes back. I have noticed that when this happens, the tachometer digital display goes out as well - the two seemed to be linked, but not sure why. The boat does have a low depth alarm setting (Depth Sounder) which is connected to the Speedometer Digital Display.
          What I have done:
          • Replaced Speedometer, it has never really worked. I have the original one as well and think it probably works.
          • Removed the Faria Gateway box - opened it to see if it had water damage or obvious burns or damage. It looked really clean, so I resealed it and reinstalled it. After reinstalling the Gateway box, nothing changed, but issues remained consistent, nothing new was detected.
          • Cleaned all plugs, wires and connections with electronic cleaner spray and inspected for corrosion.
          • While disconnecting plugs on the gateway, I noticed the wires on the Speedometer Plug that go to the Gateway Box, was missing the insulation and looked a bit frayed. I recovered it with electrical tape, but think this may be a potential source or related to the issue.
          • After putting everything back together, I tested the boat on the water, everything was the same as before, the buzzing alarm sound did not start for about an hour, but eventually did. I have disconnected the speedometer at the gauge hoping this at least eliminates the beeping noise in the future.
          • jkallen21
            • Jan 2013
            • 399
            • United States
            • 2006 Super Air 220
            Follow the perfect pass wire from the dash. The ECM is located under the helm.
            • tmorefi
              • 39
              • San Jose, CA
              #21
              Removed my gateway box to try and clean and have removed all 8 screws but can't get it open. Am I missing something? Or just think it's super sealed and need to find a way to break the seal. Any insight?
              • ScooterMcgavin
                • 1478
                • 2014 SAN 210 TE
                #22
                Yes it’s sealed for sure, heat gun and pry tools
                1989 Sport Nautique
                • fsts2k
                  • Nov 2004
                  • 215
                  #23
                  Gently slide a screw driver at the top and it will split apart
                  • Timmyt220
                    • May 2023
                    • 1
                    • South Carolina
                    • 06 Sup220 89 Mastercraft 06 Harris tri toon
                    #24
                    Old topic on this, but how do I get the connectors off this Stingy gateway. Very awkward position and mine has no pitot tubes. Hope im not pulling it apart for nothing. 06 220San
                    Thanks.
