Just got my new--to-me '14 200 OB back from the shop after some warranty work on the cooling system. Still seems to run warm as compared to my 196. I'm seeing 168=173 at idle and 178-184 running at 3500 rpm. Is that normal? PCM lists 160 in their manual but wasn't sure if they simply ran warmer because of the semi closed loop.
Tags: None
Mine runs around 170. Did they replace the impeller? I just replaced mine after two summers of use and I was surprised at the amount of wear on it.
They replaced the impeller, the coolant and the internal water pump. I wonder if it still has a bit of air trapped in with the coolant. I have added a bit of Dexcool as directed by the shop but the temps remain fairly steady.
UPDATE....I have had it out for 7 ski sessions now. Temps now peak at 178 while running the course and about 173 at idle. It has taken about a quart of DexCool so I presume it must have been some air in the system after the new coolant went in.
