Super air nautique 2005 - excalibur 330
My boats perfect pass is set up for RPM and wont run with it on MPH, this is how i noticed the problem... My boat would normally run 22 MPH at around 3000 rpms with my ballast full. I took it out in the morning and put my boat up until my afternoon set. Once i took it out in the afternoon my driver set it to the same RPM range as normal with the exact weight as before but my boat wouldnt reach the speed it normally did. I had to run it around 3400 RPMs instead of 3000.. wind was not a factor... Boat sounds fine and i changed all spark plugs. Im wondering if its a prop? (prop has no visible damage)..
Has anyone had this problem before that can give me some advice??????
