Engine Problem, Need suggestions..
  • DavidF
    • Sep 2004
    • 611
    • Austin, TX
    Yes, one bad spark plug would not explain your symptoms. All you would expect from one bad plug is a miss at idle and speed plus a bit of a loss of top RPM/speed.
    • surroundsound64
      • Jul 2005
      • 2147
      • Longview, TX
      • 2018 230 1981 Ski Nautique
      Unless the engine was really out of time. Then, depending on which cylinder it is on the firing order, it could possibly cause those problems. The likely hood isn't much, hehe... but if you wanna get down into the degrees of the CS rotation and all that I think it's possible.
      Maybe the fuel pump will fix it. Hopefully.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
