Is this normal?
  • Baken
    • May 2005
    • 45
    • WA
    Is this normal?
    Can fresh water do this? I ask this because I was told I shouldn't see much rust unless it was in salt water.
    Also should I have anything done to the port holes:
  • Andrew
    • Aug 2005
    • 891
    • Tuscaloosa, AL
    RE: Is this normal?
    looks pretty normal, where theres water there will more than likely be rust. it wouldn't hurt to mill those ports out and polish them, but u won't see much gain from doing so either.
    • Rick
      • Mar 2004
      • 1250
      • San Diego, Ca
      RE: Is this normal?
      Looks normal to me. The ports just need to be smooth to seal with the new gaskets. I would polish them twith a rotary wire brush stuff little rubber balls or rags into the ports to prevent anything getting into the cylinders . This is very important as you don't want a spec of rust to get into the cylinder and score a piston or the wall The little red balls you use to exercise your hands should work well
      Nautiqueless in San Diego
      • DavidF
        • Sep 2004
        • 611
        • Austin, TX
        RE: Is this normal?
        It is normal. No water comes into contact with those areas anyway. More than likely you are just seeing surface rust due to the high heat cooking off the paint and water vapor condensing on the part when cold.
        • M3Fan
          • 1034
          RE: Is this normal?
          What they said- looks very normal to me.
          2000 Ski Nautique GT-40
          2016 SN 200 H5
          www.Fifteenoff.com
          • gotpwr
            • Aug 2004
            • 244
            • Louisville, KY
            • None
            RE: Is this normal?
            Ditto. You will never keep paint on anything that close to the exhaust ports.
            2000 Air Nautique Powered by FORD <-- Former Boat
