07 SAN 236- cooler floor drain not draining
  • kylem03
    • Jan 2009
    • 178
    • Wisconsin
    • 1983 Ski Nautique 2001 1994 Sport Nautique 1995 Super Sport Nautique 2007 Nautique 236
    Long story short is that I have my cousins 236 at my house for the rest of the month. Wanted to perform a nice gesture and completely cleaned all interior vinyl as the boat sits outside uncovered in the water most of the year and hasn't had a deep clean in 2 years. Problem is, after rinsing everything, I have about 3" of water pooled in the recess for the cooler in the starboard rear part of the arena.
    I have the cooler out of the space and took the chrome grate off to see if it was a plugged hose. Come to find that the top deck which the cooler sits on overlays another floor about 1.5" below and there is nothing to "unclog" that I can tell since the subfloor runs both laterally and forward/back the same size as the cooler floor area.
    I tried to take a running hose and jam it through the hole and all the way sideways and back to see if the water pressure would dislodge anything. Eventually water was seeping through the carpet under the right rear seat but quit doing so when the hose was turned off.
    Anyone have any ideas? I'm at a loss. Thinking maybe the subfloor has a "lip" of sorts whereby unless the water flows over it, it's not goin anywhere.
    Thanks,
    Kyle
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    You sure hull is not full up to drain?
    2008 210 SANTE
    • kylem03
      • Jan 2009
      • 178
      • Wisconsin
      Yep. No water in hull at drain plug
      • shag
        • 2217
        You could try a long, somewhat flexible snake... Otherwise just get a shopvac and you're done a 5 minutes...
        • kylem03
          • Jan 2009
          • 178
          • Wisconsin
          Yeh I think I'll do the shopvac idea. I pulled the carpet back from the sides underneath the corner bench and it is as I expected. There is a lip that the water has to flow over in order to fully drain from that area. Thanks!
          • jkallen21
            • Jan 2013
            • 399
            • United States
            • 2006 Super Air 220
            No good deed goes unpunished
