Ballast fills when not in use
  • MJB
    • Jun 2006
    • 229
    • Jacksonville, Florida
    • 2014 G23 Coastal Previous Boat: 2011 Team 230
    I have a 2014 G23 and my starboard ballast fills up when boat is docked and ballast is not in use
    Any ideas?
  • ski4evr
    • May 2010
    • 613
    • Bowling Green, KY
    • 2005 SV 211
    Impeller in ballast puppy shot and letting water past? does it fill and drain properly?
    2005 SV-211
    • Superbawn
      • Aug 2016
      • 25
      • Plymouth, Minnesota
      • 2016 SAN G23
      I had the same issue with my 2016. When it sat overnight the starboard ballast would read 40% full the next day. I decided to check to see if the valves were closed all the way and the starboard tank valve was slightly open when I pressed down on it. I think the cable just needs to be lengthened, but I haven't taken the time to do it and I don't want to take it to the dealer for such a simple fix. For now I just press the valve closed before I cover it up and that has been working for me. Hope that helps!
