07 San 236 not charging
  • kylem03
    • Jan 2009
    • 178
    • Wisconsin
    • 1983 Ski Nautique 2001 1994 Sport Nautique 1995 Super Sport Nautique 2007 Nautique 236
    So dropped my cousins boat in the water yesterday. Anytime I can remember it the gauge showed over 14 v when running. After turning on a ballast pump, I watched the gauge drop to 11.8. Confirmed this on the tac digital read out also. While running, I Checked voltage at each battery. Each was at 12.1. Isolation switch was on 1+2. Checked voltage wire at alternator - 12.1. Checked voltage at alternator output - 12.1.
    Shut off engine and did the same. Voltage was +/- .2 volts all the way around.
    My thought is that the alternator is smoked and that's where I need to start the diagnosis.
    Thoughts??
    Kyle
  • SVXTC
    • Feb 2010
    • 26
    • North Dakota
    • 2013 G23 2012 Super Air 230 2006 SV211 2005 SV211
    I would first check the Voltage regulator or for a loose or slipping serpentine belt.
