Upgrading '07 PerfectPass (DigitalPro) on Faria Gateway to StarGazer
  • MichaelD
    • Jun 2007
    • 71
    • Raleigh, NC + Lake Gaston, NC
    On 2007 Team Edition Nautiques, the factory put the PerfectPass chip to the "Faria Gateway" box.
    That is nice, until PerfectPass won't acknowledge button presses from the display unit. I've done enough part swapping with another '07, and identified the problem is somewhere on the Faria Gateway box by the driver's knees. All the gauges on the Faria Gateway work just fine, including the PP module showing paddle wheel speed (with "System Off").
    Has anyone upgraded their '07 with PP on the Faria Gateway to PP StarGazer (GPS)?
    If so, did you encounter any cabling headaches for cables that were designed to be plugged into a Faria Gateway versus a PP SG Master Module?
