2001 SAN Perfect pass wont stop beeping and wont engage?
  • foo
    • 37
    • Five Points,NC
    This started suddenly and now the system will not engage or appears to be searching what to do when activated. It beeps constantly even when not using PP?
    jaime blanco
  • Quinner
    • 2246
    • Correct Crafts
    Would try doing a system reset, Press and hold on/off & menu while powering up, press ^ which = yes as you are prompted.
    If that does not correct it call PP, they are great with troubleshooting.
    • 2001SAN
      • Apr 2012
      • 203
      • Ireland
      • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
      Low voltage issue can cause constant beeping. I had a similar issue due to a crappy battery.
      D.
      • Rusty Barras
        • Dec 2014
        • 180
        • new orleans
        • i own a 2001 super air nautique
        I had this problem. Check your voltage. It cuts in and out like that when it sees low voltage
        Sent from my SM-G920V using Tapatalk
