Ramlin Trailer Problem
  • NSV
    • Jul 2025
    • 43
    • Youngstown, OH
    • 2001 Ski Nautique
    We picked up our new 211 today and the Ramlin trailer will not back up. The brakes just lock up. We have a 7-way to 5-way adapter that the dealer gave us. Is there something we are missing? The actuator on the trailer is a Titan Model 60 Lever-Lock Coupler.
  • Christopher-W.-Becker
    • Dec 2003
    • 168
    • Ann Arbor, MI
    RE: Ramlin Trailer Problem
    NSV,
    Are you by chance trying to back it us a grade...even slight?
    Christopher W. Becker
    9323 Mockingbird Ln
    Saline, MI 48176
    cwbecker@umich.edu
    • NSV
      • Jul 2025
      • 43
      • Youngstown, OH
      • 2001 Ski Nautique
      Yea it is a very very slight grade. Do these couplers not have a electric lock out for reverse? Here is a pic of the boat on the drive.
        • Dec 2003
        • 168
        • Ann Arbor, MI
        NSV,
        Yes they do BUT. When you pull forward slightly to correct angles, etc the slight down grade puts pressure on the system. Then when the lock kicks in when reverse is engaged, it stays locked.
        I have a cold chisle that I insert in the slides slots in the head to get back the boat in the garage. I can send a picture if it does not make sense.
        Drove me nuts...when I could not get a F350 DRW diesel to push the boat in the drive and chirped the tires on the truck. At least I know the brakes WILL Stop the trailer.
        9323 Mockingbird Ln
        Saline, MI 48176
        cwbecker@umich.edu
          • Dec 2003
          • 168
          • Ann Arbor, MI
          NSV,
          Here are a few pics of my "FIX". Works like a champ.....CRAFTSMAN to the Rescue. I keep it in the door of the truck all the time so I can grab it just before I begin to back, BEFORE the pressure gets on the cylinder.
          Hope this helps.
          9323 Mockingbird Ln
          Saline, MI 48176
          cwbecker@umich.edu
          • Skidave
            • May 2005
            • 697
            • York, PA
            I have the same coupler on my trailer. I also have the reverse lockout solenoid. However, I drilled a small hole in the side of the coupler to insert a lcokout-pin. Some couplers come with a hole predrilled. The idea is the same as the chisle, to prevent the tounge from compressing the master cylinder piston. I went to Lowes, they have a selection of release pins with a keyring loop, picked one, drilled a hole and slipped the keyring loop over my emergency release brake cable so it does not get lost.
            It sounds like your adapter wiring might not be allowing the solenoid to come on in when in reverse.
            Hope this helps.
            Dave
            • ozark_skier
              • Mar 2005
              • 21
              • Ozarks USA
              Use the hooks on the safety cables.
              I have the same trailer coupler. Once or twice backing up my driveway (which is steeper than yours) the brakes would lock. When I wiggled the adaptor and made sure it was plugged in correctly I could hear the solenoid click (when the truck was still in reverse) and all we needed to do was pull forward to release the brakes and back it right in. Before I purchased the adaptor I learned if you run both of the safety hooks (on the coiled cables) through the slot they will also hold the brakes open. One hook is not wide enough though, it has to be both. The dealer recommended I do this anyway (plug adaptor or not) but I usually forget.
              • noti_dad
                • Jan 2005
                • 214
                I back up a 8-10 degree slope to get my 211 into the garage. I have a DHM trailer with the electric lockout and have never had a problem even when I pull forward, stop and continue in reverse up the hill. Might want to have the selenoid checked.
                • Flux
                  • 408
                  • Palmdale, Ca.
                  Definately look into the wiring, not all 7 round adapters account for the lockout thing.
                  • G-man
                    • Jun 2004
                    • 428
                    • Allen, Texas
                    X2 have the reverse soliniod checked, you can also check the 7-5 plug for voltage at the reverse wire
                    Current
                    Previous Fleet
                    • NSV
                      • Jul 2025
                      • 43
                      • Youngstown, OH
                      • 2001 Ski Nautique
                      Thanks for all the help! We checked the the wiring and everything is getting power, so I'm thinking it is the selenoid.
                      • ScrewPusher
                        • Feb 2006
                        • 77
                        • Isle of Wight County, Va
                        I have the Ramlin also, but have had no problems. Check to see if the reverse lights on the trailer (white ones on side) are lighting up. The back up solenoid and the reverse lights are the same power source, your vechicle revers lights. If you have lights, they you can assume it's the solenoid, if not you really gon't have the reverse lights hooked up @ the 7/5 way
                        • jthooker
                          • Jun 2005
                          • 68
                          • Mansfield, OH
                          The solenoid valve that RamLin uses is a “normally open” valve in the brake line between the master cylinder and the brakes. If your brakes are already engaged when you shift into reverse and the valve closes, it simply holds the pressure on the brakes and they won’t release. If you know that you’re going to encounter that situation ahead of time then you can insert the cold chisel, lock-out pin, safety chain hooks, etc. to keep the brakes from ever actuating. The problem occurs when you’re on the road, stop on a downhill grade, then have to back up for some reason. The solution is to install a “normally closed” valve and a return line that releases the pressurized fluid back into the master cylinder.
                          Kodiak has a discussion about the two types of valves on its web site here:
                          http://www.kodiaktrailer.com/redswish/brake_faq's.htm
                            • 16680
                            I had to replace my solenoid last year. It was leaking fluid all over the place. It isn't too expensive. It was about $40 if I remember correctly, and is quite easy to replace. Just be sure to bleed the brakes after installing the new unit.
                            • todda
                              • Jan 2005
                              • 281
                              • Granite Falls, WA
                              • 1999 SNOB
                              Yeah, NSV, my buddy had the same problem with his 'Bu on his Ramlin trailer. Like Becker did with his chisel, my buddy would insert the handle end of his 1/2" socket wrench in there, and it accomplished the same thing. "Hillbilly brake lock-out" we called it! Yellow_Flash_Colorz:
                              Todd
                              Todd Aalbu
                              1999 SNOB
                              66.5" HO S2
