2001 (year) Ski Nautique Dash
  • Apexnautique
    • Apr 2014
    • 4
    • A, A
    • 1997 Ski Nautique 197 Closed Bow, Early Production GM Apex 350
    Hello
    I'm working on a 2001 Bubble Back Nautique. The dash only has a 3 volt supply to it. Nothing works from the dash on the keypads.
    Battery has 12.5 volts. Jumping at the solenoid will easily crank the engine over with 12 volts power. Cleaned the paint away from the engine ground and cleaned the cable ends.
    Is there a way to open up the fusebox at the foot plate or are they totally sealed up?
    I had tested the 3 volt supply at the connector to the start pad. lights did work but now faint on the keypad.
    Battery is suppling 12.5 volts out of the main power cables.
    Thanks for your replies.
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    Check the fuse by the battery. There is a separate 20A car type blade fuse in a fuse holder which powers the dash.
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
    • Apexnautique
      • Apr 2014
      • 4
      • A, A
      Thanks Fast351. I owe you a ripe on the course. The fuse was all corroded. I put a new one in. Measured voltage at the keypad connection. Back to 12 volts again and everything powered up.
      Thanks again.
