Shaft movement?
  • onenautiqueone
    • Apr 2025
    • 89
    • Nor Cal
    Shaft movement?
    I am getting ready to install a new prop and I had noticed some play in the shaft, ( 16th of an inch +-)not much but it is there. Prop to shaft is solid it is the shaft to shaft mount is where the play is. Should this not move at all or is there supposed to be some play in the shaft mount?
    Thanks....
    • 2908
    RE: Shaft movement?
    probably needs new strut bushings. Side to side, right? not fore/aft.
    • onenautiqueone
      • Apr 2025
      • 89
      • Nor Cal
      Yes, it is side to side
