I have a 1998 Ski Nautique. Recently lost my fuel cap. Turns out it is next to impossible to replace with the correct size for this model. Right now I have a cap that is 2" in place but it is just a little too big. I am considering replacing the fuel filler neck. The problem is I do not know how to remove the rear seat back for access. If I pull up on it, it moves a little but I don't want to break any fasteners that I am not aware of. Also, I had what I believe to be a vapor lock problem this summer and read on this site that cleaning the anti siphon valve might be a possible fix. That too is located behind the rear seat back that I don't know how to remove. By the way, to deal with the vapor lock problem I open the engine cover to let the heat out if I am turning the boat off for an hour or so. It seems to work out, but does not fix what is causing the problem. Thanks
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
There are two rubber hold-downs at the bottom, connected to the support bars that come down from the gunnels near the seat back. Just unhook those two, and lift straight up.
You may need to pull the seat bottom forward in order to see them.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
